Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: add a member to HomePieceOfFurniture » » » » Post: Re: add a member to HomePieceOfFurniture |
Print at Sep 20, 2026, 6:03:07 PM |
| Posted by Puybaret at Nov 15, 2010, 5:41:44 PM |
Re: add a member to HomePieceOfFurniture Sorry, but no one will be able to find a bug in your code, if he doesn't see the part you changed! I suggest you to use a debugger to be sure that you set the fields and the variables values as expected. By the way, "witch" is "sorcière" but I guessed you wanted to use "which" instead! ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 20, 2026, 6:03:07 PM |
