Print at Sep 20, 2026, 10:19:39 PM
Posted by ckuppel at Nov 15, 2010, 10:43:31 AM
add a member to HomePieceOfFurniture
hello everyone,
I try to edit the stucture of the "HomePieceOfFurniture" model by adding member. I alredy added the member, the getter and the setter, i modified the different views by adding an input field for this member (import and edit by double clicking on the object on the plan 2D).
I don't know where (or when) the listener witch use the setters of "HomePieceOfFurniture" is called.
this is a list of file modified :
HomePieceOfFurniture.java
homeFurnitureController.java
When i importing a furniture or when modify one, i fill my text input associated to the member, then there the value of the memberis still Null.
Do someOne has an Idee?
Thank you
[Note from moderator: please no translation. If you prefer to speak French, please post in the French section]
