Print at Sep 6, 2026, 11:40:43 AM
Posted by jgriessen at Nov 1, 2010, 5:01:58 PM
Re: workaround javaws worked, but needs downloads each time I use it...
"The easiest Ant target is probably the one named jarExecutable."
Oh... I figured that out and built it with no errors.
ant makes a file install/SweetHome3D-2.6.jar
When I execute that it puts this to the screen:
john@toolbench:/moredata/SweetHome3D-2.6-src/install$ ./SweetHome3D-2.6.jar
Java 3D WARNING : reported GLX version = 1.2
GLX version 1.3 or higher is required
The reported version number may be incorrect. There is a known
ATI driver bug in glXQueryVersion that incorrectly reports the GLX
version as 1.2 when it really is 1.3, so Java 3D will attempt to
run anyway.
Segmentation fault
John
