Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Problems will wall lengths » » » » Post: Re: Problems will wall lengths |
Print at Sep 21, 2026, 9:35:00 PM |
| Posted by hansmex at Oct 11, 2010, 12:37:18 AM |
Re: Problems will wall lengths Shadow, Your observation is correct: walls are drawn from "centre to centre". If you need EXACT interior dimensions you have to take this into account. Workarounds: 1 - You could make your walls 1 cm (one) thick and add that centimeter to the length of your walls. 2 - You could draw a floor first, and using the Advanced Resize plug-in you can edit the floor to exactly match your dimensions. That done, you can surround your floor with walls. Now use this trick from Emmanuel: "One last tip: the easiest way to design just one room is probably to draw it first with the Room creation tool, then choose Wall creation mode and double-click in the room to automatically create the walls around it." Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 21, 2026, 9:35:00 PM |
