Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How do you work the lights again? » » » » Post: Re: How do you work the lights again? |
Print at Sep 6, 2026, 5:51:55 AM |
| Posted by db4tech at Sep 19, 2010, 9:40:49 PM |
Re: How do you work the lights again? Hi pencilart, I think I may have an idea about what is going wrong!? To install the lights, don't use. "Import furniture..." Instead you need to use "Import furniture library..." You should then see a directory called "Light bulbs" ![]() As seen in this image. ![]() Hope this helps! PS: Just tried making 4 walls then adding a door and a window, then moved the walls, no extra walls are created. db4tech |
Current timezone is GMT Sep 6, 2026, 5:51:55 AM |
