Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Apply a texture on a door » » » » Post: Re: Apply a texture on a door |
Print at Sep 13, 2026, 10:33:45 PM |
| Posted by hansmex at Sep 17, 2010, 1:49:33 AM |
Re: Apply a texture on a door Hutch: There's another solution: - insert a doorframe of the required size; give it a colour or a texture - inside the doorframe, insert a box of the correct size - choose Modify -> Texture , choose the texture of your liking, but do NOT apply it - choose Modify and give the texture the exact height of the box that you inserted inside the doorframe If all is well, you should now see a texture that repeats exactly once (vertically). If the width of the texture isn't correct, you will have to use a graphics program to change the size of the texture to exactly match the size of the inserted box. I hope I explained it clearly enough. Good luck. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 13, 2026, 10:33:45 PM |
