Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: Easy 3D light bulb positioning » » » » Post: Re: Easy 3D light bulb positioning |
Print at Sep 14, 2026, 3:05:23 AM |
| Posted by Puybaret at Sep 12, 2010, 11:23:06 PM |
Re: Easy 3D light bulb positioning db4tech, I don't know how you tried bump mapping in the advanced rendering plugin, but each time you want to try a new feature of SunFlow, you should try this: - Search the SunFlow feature you want in SunFlow wiki. For example, bump mapping is explained here. - Look at its SunFlow syntax, for example: modifier {- View SCParser class, which contains all the Java calls matching a SunFlow feature. - In this class, look for the syntax words found in the Wiki. Looking for "bump" will bring you to the line 613 in the parseModifier method. - Reproduce the Java syntax in your program from the calls made on the api object. For bump mapping it seems to be this: this.sunflow.parameter("texture", filePath);I hope this will help you. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 14, 2026, 3:05:23 AM |
