Print at Aug 25, 2026, 11:16:20 AM
Posted by whippetsleek at Sep 9, 2010, 7:45:15 AM
Re: Color of walls: problem
Like Hansmex, I don't like a mystery either, so I downloaded your file Rob123, and noticed your wall transparency is slightly moved. If you move the wall transparency slider all the way to the left, You will get a good solid wall. You are getting the glass look because the renderer thinks of the walls as transparent. Here is the render I got...
I see your file is in what I believe is french, so if I haven't explained clearly enough, maybe someone can translate this into french for you...
BTW, Very nicely done home, it looks excellent.
