Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: Easy 3D light bulb positioning » » » » Post: Re: Easy 3D light bulb positioning |
Print at Sep 14, 2026, 3:05:18 AM |
| Posted by db4tech at Sep 9, 2010, 5:51:58 AM |
Re: Easy 3D light bulb positioning Thank you! I'm sorry to say I've got a bit stuck though. My original idea worked but found out it did cause another problem. So after undoing those changes, and having a rethink, I'm trying to add a new exception rule. Just to test my new exception rule idea works, I temporarily disabled the 2 lines below, I haven't learned enough yet, to know how to let shapeName.startsWith("sweethome3d_light") have it's own exception rule. The idea does work, I just need help on how to proceed, to give sweethome3d_light, its own exception rule.// Build a unique object name String uuid = UUID.randomUUID().toString(); String appearanceName = null; TexCoordGeneration texCoordGeneration = null; if (appearance != null) { if (ignoreWindowPanes && shapeName != null // && shapeName.startsWith(ModelManager.WINDOW_PANE_SHAPE_PREFIX) // && isDoorOrWindowChild(shape) && shapeName.startsWith("sweethome3d_light") ) { return; } texCoordGeneration = appearance.getTexCoordGeneration(); appearanceName = "shader" + uuid; boolean mirror = shapeName != null && shapeName.startsWith(ModelManager.MIRROR_SHAPE_PREFIX); exportAppearance(appearance, appearanceName, mirror, defaultShininess, silkRendering); } I have tried several things, to let sweethome3d_light have its own exception rule but I'm soon starting my next course semester and hoped to get this finished before then. So rather than struggle by myself, I thought maybe it's best to ask for help.Thank you in advance! Good idea about also using 1.6.1 extension for the lights. db4tech |
Current timezone is GMT Sep 14, 2026, 3:05:18 AM |
