Print at Oct 15, 2026, 6:08:10 PM
Posted by cedricvale at Oct 15, 2026, 1:51:02 PM
Re: Planning LED Lighting in a Room Designed with Sweet Home 3D
Thanks, that distinction helps. I hadn't considered treating the visible fitting separately from the actual light it casts. For under-cabinet LED strips, would you normally use several invisible light sources to create the spread across the worktop, rather than relying on the strip model itself?
