Print at Oct 5, 2026, 4:03:40 PM
Posted by Keet at Oct 1, 2026, 6:29:17 PM
Re: Issue trying to restore purchase
All models are stored in the project file (.sh3d) so those should be available as before (i.e. present in the project). You can export them and import in your catalog for use in other projects. Unfortunately that will not keep specific properties that are only available through a furniture library. But when you directly copy a model from your existing project to a new project it will retain the properties.
It is possible that you still have access to your old (purchased) install on your drive. Look for "Furniture.jar" in the install Lib directory. Replace the Furniture.jar in your new (7.5) install with that one. (First backup the jar file from 7.5). You will have to try that, might just work. Furniture.jar holds the models that are installed by default in your catalog when you install Sweet Home 3D.
Anything further I can't help you with unless it is for the 7.5 open source version. The newer paid versions are starting to divert too much from the last open source version. And since I'm om Linux I can only use that last open source version.
