Print at Sep 21, 2026, 11:18:51 PM
Posted by db4tech at Sep 2, 2010, 12:32:41 AM
Re: my bathroom
The Ni value is the index of refraction. smile
Reason you aren't seeing any lights is because the lights need something to bounce off. wink That's why I mentioned about not making them out of glass (That was one of my first ideas, a glass outer and a smaller solid inner)
Make them as an ordinary surface, then place your light in the middle and increase the light dimensions until the light just appears on and past the surface.
with your quotes did you check to see the you always had |quote| then |/quote| ? (I can't use the brackets of course or you won't see the quote text)
I do have a consultation fee by the way! biggrin
db4tech
