Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Select Hide Utility plug-in » » » » Post: Re: Select Hide Utility plug-in |
Print at Sep 13, 2026, 2:19:29 PM |
| Posted by Xlance at Sep 4, 2026, 2:39:20 PM |
Re: Select Hide Utility plug-in Hey All Select & Hide Plugin v1.7 is now posted on sourceforge The Select & Hide plugin adds powerful selection, visibility, and hide/show controls to Sweet Home 3D. Selection Tools Select Walls Select Rooms Select Dimension Lines Select Labels / Text Select Lines / Arrows Select Doors Select Windows Select Stairs Select Lights / Lamps Select Other Furniture Select Multi-point Polylines Invert Selection Option to apply selection to all levels or only the current level Select furniture by name or description Multiple search terms can be entered for more precise matching The selection system also handles furniture groups and their child objects while preserving level information. Hide / Show Tools Objects can be hidden by category: Walls Rooms Dimension Lines Labels / Text Lines / Arrows Doors Windows Stairs Lights Other Furniture Multi-point Polylines Additional actions include: Hide All Selected Show All Hidden Hide furniture by name or description Apply operations to all levels or only the current level Smart Text Search Furniture can be found using text entered in the input field. Searches are performed against both the furniture name and description, with multiple words supported. Level-Aware Operation Selection and visibility operations can be restricted to the currently selected level, or applied across all levels. This makes the plugin particularly useful for multi-story projects. Safe Hide / Restore Hidden walls retain their wall-joining information so that restoring them can reconnect the original wall relationships. Polylines are also restored in their original order. Undo / Redo Hide and show operations are integrated with Sweet Home 3D's Undo / Redo system, allowing visibility changes to be reversed and reapplied. User Interface The plugin provides a dedicated dialog with two tabs: Select Category selection Select all levels Invert selection Text input Hide / Show Category-based hide controls Hide selected Show hidden Text-based hide/search The plugin also supports a modern FlatLaf interface when available. Highlights A fast and flexible way to: Select large groups of objects Hide unwanted objects while editing Work efficiently with multi-level homes Find furniture by name or description Temporarily simplify complex floor plans Restore hidden objects without losing important wall/polyline relationships Undo and redo visibility operations https://sourceforge.net/p/sweethome3d/plug-ins/23/#f142 ---------------------------------------- Windows 64bit | Intel i7 | 8GB Ram | SH3D 7.5 + Plugins |
Current timezone is GMT Sep 13, 2026, 2:19:29 PM |
