Print at Sep 26, 2026, 7:45:02 AM
Posted by [email protected] at Jul 23, 2026, 11:18:26 AM
Re: Generic European Schuko wall socket – SH3F furniture library
Sorry,
I forgot that by doing this, the objects placed in place can each vary in content. That is, you can add a simple Schuko socket where there was a single socket, or you can add a switch and a multipurpose Schuko socket, or you can swap their positions simply by adjusting the relevant textures.
Regardsstumbled upon this discussion of yours.
I believe that, worldwide, new electrical installations rely on modern standards based on fixed-size, numbered wall boxes—whether flush-mounted or surface-mounted (types 501, 502, 503, 504, 505, 506, 508, with the initial digit—5 or 6—indicating the intended use: flush-mount vs. surface-mount). The final digit indicates the maximum number of electrical modules (inserts) the box can hold. These modules can be single, double, or triple units, but they all share the same maximum depth—dictated by the box itself—regardless of the manufacturer.
The box accommodates any mounting plate produced (it is the plate that actually determines the type and number of modules contained).
A decorative cover plate—chosen for shape and color to provide the visual finish—is then placed over this assembly.
Following this logic in Sweethome, the actual content of the electrical module is simply an image of the real finished product (perhaps with a depth effect) placed upon a standard-sized structure (width and depth) that represents it—albeit with some approximation, as we are dealing with minimal visual dimensions that wouldn't be visible except in an exploded view. This sequence makes the construct independent of the specific finished product; any international module style can be applied to the individual electrical unit. The box will be recessed into the wall (or surface-mounted, in the case of external boxes), and the conduits carrying the system's wiring will be attached to it; only the decorative faceplate—and the functional electrical components—will be visible flush with the wall surface (note that decorative faceplates cannot be used with surface-mounted boxes).
This logic could lead to the creation of a construction plugin featuring texture libraries: one for regional formats (UK, US, IT, etc.) representing standard national socket types; one for the various standards of mounting boxes (flush-mount vs. surface-mount); one for the individual module structures (blocks with fixed depth and height but variable width); and one for decorative faceplates (shapes and colors) along with the associated logic (e.g., a box holding a maximum of 3 modules could accommodate one 1-slot and one 2-slot module, or three 1-slot modules, or various combinations—including "blank" filler modules). As I am neither an expert nor a Java programmer, I won't be attempting this myself.
IIn my own older SweetHome projects, I used a similar technique (creating my own library) to establish a single-brand standard (BTicino) with combinable layouts. I utilized the ability to toggle the visibility of individual modules on a standard mounting bracket and applied the chosen function texture and faceplate color to them. The result was visually realistic—even when zoomed in—and, by using wall transparency, the setup could be used to map out the actual electrical wiring.
I am sharing this simply to inform others and perhaps suggest this possibility to anyone who might be interested.
Best Regards.
