Print at Sep 26, 2026, 12:03:42 PM
Posted by Keet at Jul 23, 2026, 6:53:32 AM
Re: Generic European Schuko wall socket – SH3F furniture library
About not needing the rotation correction: When you export an object in Sweet Home 3D the object is exported with its position in the 2D design pane. Your initial socket could have been corrected by rotating it in the 2D pane with the correct side to the front before export.
You can see the result when you rotate an object 45° and export it. When you import it again it has the same 45° position as when you exported it.
