Print at Sep 13, 2026, 10:34:24 PM
Posted by Puybaret at Aug 27, 2010, 10:30:29 AM
Re: Simulate sun position and lights/shadows
By the way I forgot to mention that from version 1.6, the sphere of the bulb lights coming from the updated SH3F files have a diameter equal to the maximum value between their width and their depth (so it will be 10 cm by default).
The sphere of the other lights have a diameter equal to 6.5 cm that allows to use almost all the lights of the available SH3F files as light sources (see image bellow), but may change how your images will look compared to the previous versions of the plug-in.
If this last diameter is too large, you always have the option to import again the given light from 3D models page with the import furniture wizard, then you add one of the updated bulb lights in the imported light and change the size of the light bulb.
