Print at Jul 21, 2026, 4:47:51 PM
Posted by Xlance at Apr 14, 2026, 1:55:48 PM
Re: Modeller 3D plugin
- Make the coordinate spinners a little larger, the decimal number is only displayed half with two digits before the decimal point. Most sizes used in Sweet Home 3D are between -1000 and 1000 and the precision is 1mm = need to completely display 999.9 or if possible -999.9. It looks like there is room for it in the panel.
Fixed
- Don't forget to look at the selection process.
Actually the use of right click is very common and convenient
- close and start the plugin again. Import another object from a different location. Now it asks for a filename to store? <enter> and (maybe) the object is stored somewhere but I can't find it. Probably no save at all.
- even after closing Sweet Home 3D and opening the same project again the plugin does no longer display the save/cancel buttons.
Works fine with me
- all textures are lost, everything gets the same material definition.
Fixed for *.obj and *.3ds
- Imported *.dxf files with Arcs, Splines, Lines or Mixed.
Fixed
https://www.mediafire.com/file/cwxkgal36msa8l5/Modeller3D-1.4.5.7.sh3p/file
Windows 64bit | Intel i7 | 8GB Ram | SH3D 7.5 + Plugins
