Print at Apr 30, 2026, 6:31:55 PM
Posted by Sindrela_Casper at Apr 14, 2026, 12:45:56 PM
Re: Removing measurments
When importing background images or textures into Sweet Home 3D, I've found that the software handles things much better if the file is already trimmed down to just the area you need. It really helps with alignment and prevents the 'jumping' glitch when you're trying to trace walls.
If you don't have a photo editor open, When importing background images or textures into Sweet Home 3D, I've found that the software handles things much better if the file is already trimmed down to just the area you need. It really helps with alignment and prevents the 'jumping' glitch when you're trying to trace walls.
If you don't have a photo editor open, https://www.thetoolapp.com/crop-out-image/ is great for quickly cleaning up floor plan scans or textures before you import them. Hope that makes the setup process a bit easier for you! is great for quickly cleaning up floor plan scans or textures before you import them. Hope that makes the setup process a bit easier for you!
