Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Objects lose transparency when grouping » » » » Post: Re: Objects lose transparency when grouping |
Print at Sep 27, 2026, 1:12:29 AM |
| Posted by hansmex at Aug 22, 2010, 8:50:20 PM |
Re: Objects lose transparency when grouping Emmanuel, db5tech, QUOTE The other problem has something to do with refreshing the screen. When I drag an inserted door out of the wall, the door disappears and only the glass window in the door remains visible. When I do a right-click and (without selecting anything) a left-click, the screen refreshes correctly. ENDQUOTE Maybe it's a driver problem, I wouldn't know. Just seems that the refreshing isn't as fast or automatic as it should be. The right-click left-click solves the issue. As for Ubuntu: I'm using Lucid 10.04. It recognizes that Windows is already installed and proposes to do a dual install, so that you can choose at start-up. Of course you can also install it on a virtual machine. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 27, 2026, 1:12:29 AM |
