Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Terrain Generator plug-in » » » » Post: Re: Terrain Generator plug-in |
Print at Oct 5, 2026, 5:46:05 PM |
| Posted by Keet at Apr 1, 2026, 7:25:31 AM |
Re: Terrain Generator plug-in First of all: Thank you for the fast response. I misread "Grid divisions" for "Grid size". That doesn't change what happened but it clears up my understanding of the number that was written in the Home.xml file. I created a terrain with grid size 30 and a second room with grid size 50. Selecting them both and using the TerrainGenerator causes one of the rooms to display the weird spikes. What I already detected is that combining rooms with a different grid size causes problems. Make the grid division number read-only because it's just a calculation with the grid size and room size. It's not a number that you should use to change the grid, that's what the grid size is for. What is important is that with multiple rooms they all have the same grid size. Creating both rooms with the same grid size and then combine them for a single terrain is now correct. Problem solved. But you should find a way to alert users that multiple rooms require the same grid size in order to combine them. - Check on startup if multiple selected rooms have the same grid size. If not give a warning message that the rooms must have the same grid size for a correct combined terrain. Or - Automatically change the grid size for all selected rooms to the grid size of the room with the smallest grid size (most detailed). Now I have to find a nice height-map to see if that can be used for my ShoppingMall terrain ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 5, 2026, 5:46:05 PM |
