Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: Wall width does not match the entered width » » » » Post: Re: Wall width does not match the entered width |
Print at Oct 5, 2026, 6:45:35 PM |
| Posted by kkb at Feb 3, 2026, 9:22:29 AM |
Re: Wall width does not match the entered width I get it, thanks for the reply. I use local lang translation, which is not so much strict as the en one - will switch to en. Still I moved from sketchup, as I think SH3D is great but find my self in a very difficult position doing a simple walls. I tried different aproach. 1. Doing all at once (not doing double click to end) - failed, as I get wrong file width once i get to corners and wallcross. 2. Doing by Copy&paste predone walls. So I add a wall, set it length and then move one next other to merge and until I merge them its fine. When I join them they loose all valid widths and redoing them is a mess. 3. I also read on the forum I could do rooms and then double click to add walls. I also tried that but seems this is a bit buggy and some artifacts are added and this also is not usable. Reported this here How do You think I should approach doing walls from a already existing project? How to You do yours? I thought some YT guys could show me but they alwasy draw something, which they do not to be acurate (to cm) and that is okay but that is not what I need. I see this problem has been already reported her https://sourceforge.net/p/sweethome3d/feature-requests/750/ What I find useful in sketchup is https://sourceforge.net/p/sweethome3d/feature-requests/1085/ what do You use instead here? |
Current timezone is GMT Oct 5, 2026, 6:45:35 PM |
