Print at Oct 5, 2026, 8:52:56 PM
Posted by z56oo at Feb 1, 2026, 3:37:24 PM
Re: Generate terrain from a room in batch mode / Hijacking the “Generate 3D terrain from rooms…” plug-in
Hi Keet,
You can see the straight terrain features on the house because that's how I wanted it ( I could have placed more points on the building walls ) . Otherwise, the terrain itself is gently undulating because it follows the mesh triangles that snap to all the points of the room , see the screenshot below.
Your method of dividing into several rooms seems , in my opinion, more complicated and laborious than mine. I will try it sometime, though .
I would like to reiterate that I wanted to create a ‘terrain’ without spending hours on it, and by following this method I didn't even take half an hour to create this 90x90m terrain with buildings at various heights .
Furthermore, I don't even dare to calculate, with the default grid spacing of the plug-in at 50cm, the number of points for a 600x600m terrain (in fact, yes = 1.5 million points and probably as many elevations ) .
This is to say that it would be good to be able to modify the grid spacing in the plug-in.
For the time being, I’m very happy to have found this alternative
Thank you for your reply .
