Print at Oct 5, 2026, 11:16:40 PM
Posted by Daniels118 at Jan 22, 2026, 4:05:40 PM
Re: how can I position a box
I guess you feel the box moving because the camera is following the box wherever you place it. This is always the case if you have the "camera centered on selection" enabled in the settings and you have the box selected, but will also happen if the box is the only object in the scene, because the program will center the camera on the midpoint of all objects in the scene.
You could:
A) add 4 boxes on the corners of your work area, so that the midpoint won't be affected by any object in the middle, and disable the camera centered on selection option.
B) add a single box to a reference point, and select it whenever you want a certain perspective (with the option enabled).
C) use Pan3dView plug in to move the camera freely.
