Sweet Home 3D Forum » List all forums » » Forum: Gallery » » » Thread: Artificial-Intelligence-Inspired Homes » » » » Post: Re: Artificial-Intelligence-Inspired Homes |
Print at Sep 21, 2026, 6:02:35 AM |
| Posted by GaudiGalopin3324 at Jan 19, 2026, 3:36:46 PM |
Re: Artificial-Intelligence-Inspired Homes Thanks! I'm on this topic all the time and that's what I realized. To use AI as a useful tool, you need to start designing using standard classical methods. Draw with pencil on paper. And then connect AI as a tireless worker. But not the other way around. And that's exactly what SH3D allows you to start designing correctly, through primitives. And after this stage, AI will be able to turn primitives into an effective, understandable and attractive environment. I'm still experimenting with interiors. And I started to succeed!! First, the correct space is created using primitive shapes (SH3D is ideal for this), and then this primitive scene is processed in AI. And the result doesn't upset you, because you're still a creator, not an apprentice. If you give up once and ask the AI to do the first (most important!!) for you step, then there is no solution. You will feel insecure with this product. It's not yours. You are not the author. And everyone will tell you that in the end. You can't hide it. That is, of course, they hide it all, but there will be no satisfaction inside themselves. I advise you to do exactly this in your work - from simple and manual labor to routine with AI. And that's the only way. after all, this is not an argument, but just my thoughts about human work with AI. |
Current timezone is GMT Sep 21, 2026, 6:02:35 AM |
