Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Poor resolution issue » » » » Post: Re: Poor resolution issue |
Print at Feb 12, 2026, 8:49:13 PM |
| Posted by Asabinn at Jan 15, 2026, 4:58:22 PM |
Re: Poor resolution issue Hello, Trying to print/export or whatever my plan, the result is pixelated (~1cm per pixel). I've got a well defined plan on my screen, but if I print it, export it to svg, or to png using the plugin (whatever resolution I put) all plan elements are aligned on a pixelized grid of approximately 1cm, each line has a minimum width of this pixel size. Once imported in inkscape, I can move with accuracy those big pixels, but the accuracy has already been lost. Among Us Tried the icon resolution: I actually got some well defined bath&co inside pixelated walls I'm tearing my hear out on this problem sine a few hours without any solution to render an accurate plan. It rasterizes the plan internally on a fixed world grid (~1 cm resolution) and then wraps that bitmap inside SVG / PDF / PNG. |
Current timezone is GMT Feb 12, 2026, 8:49:13 PM |
