Print at Sep 9, 2026, 10:29:09 PM
Posted by Keet at Nov 25, 2025, 10:42:27 AM
Re: Furniture to Solid
Try to trace back from where the project is saved. Tracing back from save should eventually encounter the method that calculates the property values as they are saved in Home.xml. Then see if you can use that same method for your purpose. If the values aren't recalculated but retrieved from somewhere then you can trace back from there.
In my C# IDE I can call up a list of all methods that call a selected method or object. I don't know if you can do the same with Java in Eclipse but if you can that should greatly help in tracing back.
