Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Generate roof plugin » » » » Post: Re: Generate roof plugin |
Print at Sep 9, 2026, 10:11:12 PM |
| Posted by Indigo_Solo at Nov 17, 2025, 1:27:40 PM |
Re: Generate roof plugin Hello! I finally have taken the time to test this plugin, And here is my humble opinion: It is amazing! As you've seen, I spent days building the roof parts that work as a pieces of LEGO to build roofs. But, this plugin, summarizes it in few seconds, overcoming the troubles of making roofs in the traditional way (building and rotating triangles). That's why I built the parts... I know absolutely nothing about programming. Roof Generating plugin just amazed me. It doesn't leave tips of roof inside. Textures are set properly in all faces (tiles drain water to down). You can personalize the roof. The base (ceiling of the attic) could be generated as well, if you copy and then paste the roof and then set the copy below, with proper modifications. And, If don't matter, I'll tell you what would make it perfect (I've just try): If square or even round holes could be opened in parts of the roof. It could be set in one of two ways: 1. In the dialog of the plugin, before the roof generation. 2. Making the roof object, once generated, to act as a room when a stair is inserted, or a wall when a door or window is inserted. This could allow the creation of everything else: Dormers, chimneys, monitor roofs, skylights, vents... Congratulations. This has been a dream plugin. I'll give one of my hands to know programming and cooperate instead of only suggest. Have a nice day, and thank you so much for your work! ![]() |
Current timezone is GMT Sep 9, 2026, 10:11:12 PM |
