Print at Sep 22, 2026, 8:25:57 AM
Posted by Keet at Nov 16, 2025, 10:06:44 AM
Re: Saving a furniture file
The problem is probably not with your OS (which one?) or Sweet Home 3D. The most likely is a corrupted furniture file.
Try extracting the zip and import the extracted model. I believe on IOS that is the required method by default.
The zip should have one or more 3D model files of the type .OBJ(+.MTL and possible textures images), .3DS, .DAE, or .KMZ.
If that still doesn't work: Do you have the same problem with importing other models?
