Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Re: Create a solid Shape » » » » Post: Re: Create a solid Shape |
Print at Oct 5, 2026, 8:21:34 PM |
| Posted by Keet at Oct 21, 2025, 9:59:12 AM |
Re: Create a solid Shape Why do you want the rooms as solid objects? Keeping them as room objects has advantages that 'normal' objects don't have: easy to recalculate the surface when you moved a door or wall and you can punch a hole with a staircase. If you really want floors as solid objects then wait with exporting until you are finished with your project and only then export. Leave staircases visible but don't select them, the exported room will have the hole for the staircase after import. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 5, 2026, 8:21:34 PM |
