Print at Oct 5, 2026, 8:21:23 PM
Posted by Keet at Oct 20, 2025, 3:48:48 PM
Re: Create a solid Shape
What do you mean by 'solid'? An exported/imported room IS a solid object. I'm not sure what else you expect or what you need.
ETA
I looked at your file. You exported both walls and room. Select only the room and export that. After import you can adjust the height to a solid block with the height of the walls. That what you are looking for?
