Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Start Point » » » » Post: Re: Start Point |
Print at Sep 9, 2026, 9:53:42 PM |
| Posted by dorin at Oct 2, 2025, 9:40:39 PM |
Re: Start Point First: I'm sorry if I upset you! Second: In your definition, you mentioned "a wall," so I'm not entirely wrong. Third: It's better to ask us "How do I do this or that with this program?" instead of "Why doesn't this or that feature exist, like in other programs?" So, I will try to help you within the limits of my modest and anecdotal knowledge even you don't ask for. You want to have the wall with a side superposed with one of the grid lines(horizontal/vertical, major, minor). On short: You can't do this automatically. On long: Usually, when magnetism is enabled, the walls are drawn parallel with grid. You could set the wall position in that way to overlap a line of grid. If I've correctly understood you need multiple walls as equal separators of a space. When you have 2~3 walls could be made as I say above but what if you need 20 or 50 this became unacceptable. I've encountered this problem in the past. This days you could use Multiplier plugin. How? Draw a wall, set their thickness and set their position. Select the wall then Tools->Multiply... or use the toolbar icon. On Linear method set the desire numbers of walls and the distance on the needed direction. Of course will be measured from the middle so you have to add the wall thickness at distance between walls. ERRATA: Is my fault! By "constructors" I meant builders, bricklayers, plumbers, electricians, etc. The guys who worked on renovating my apartment. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Sep 9, 2026, 9:53:42 PM |
