Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Unable to Start Sweet Home 3D After Installing Pan 3D View + Wiring 4.4 Beta 2 » » » » Post: Re: Unable to Start Sweet Home 3D After Installing Pan 3D View + Wiring 4.4 Beta 2 |
Print at Oct 5, 2026, 8:21:46 PM |
| Posted by dorin at Sep 29, 2025, 9:08:45 AM |
Re: Unable to Start Sweet Home 3D After Installing Pan 3D View + Wiring 4.4 Beta 2 There exists a second, nearly identical plugin folder under: C:\Users\User\eTeks\SweetHome 3D\Plugins containing many, but not all, plugins. This duplication is confusing and complicates troubleshooting. That's strange! It should never happen. Try to make an completely fresh install as I've described and take a look into Sweet Home 3D folder after you run the program at least once. It should make all folders with lower case(e.g. plugins NOT Plugins). With some upper case could be the PluginManager folder if you've installed PluginManager-1.5.3.sh3p under plugins. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Oct 5, 2026, 8:21:46 PM |
