Print at Oct 5, 2026, 8:22:34 PM
Posted by T_R at Sep 28, 2025, 7:19:18 PM
Unable to Start Sweet Home 3D After Installing Pan 3D View + Wiring 4.4 Beta 2
Subject: Unable to Start Sweet Home 3D After Installing Pan 3D View + Wiring 4.4 Beta 2
Hello everyone,
I recently tried to extend Sweet Home 3D (Windows 11 Pro, 64-bit) with the Wiring 4.4 Beta 2 plug-in. Since the author mentioned that it requires Pan 3D View > 3.0, I first installed Pan 3D View 3.3. The application confirmed that the plug-in would be available on the next restart.
Encouraged, I immediately installed Wiring 4.4 Beta 2 as well, which gave me the same confirmation. However, after restarting Sweet Home 3D, the program would no longer start. Instead, I now only receive the message asking me to install Pan 3D View – even though it is already installed.
At the moment I am unable to open Sweet Home 3D at all.
My questions are:
How can I recover Sweet Home 3D so it will start again?
Is there a safe way to remove the Wiring 4.4 plug-in without having to reinstall everything?
If necessary, how can I disable Pan 3D View as well? I would rather work without these extensions than risk losing access to the software.
I would be very grateful for any advice or clear steps to solve this issue.
Also, if this is a common problem, perhaps it could be highlighted in the forum so other users don’t run into the same difficulty.
Many thanks in advance for your support!
Best regards,
T_R
Laptop :ThinkPad 490, WIN11Pro, 64Bit, 8GBRam, 6T Harddrive
Never give Up!
