Print at Sep 9, 2026, 10:11:41 PM
Posted by Keet at Sep 19, 2025, 2:17:43 PM
Re: Custom object properties support for SH3D furniture items
Interesting idea and some have been on the wishlists for multiple members, for example a transparency slider on the material dialog.
Different dialogs for different types of furniture is more problematic. Basically, "furniture" is a 3D mesh object and looking at it that way a bookcase is the same as a box. Most dialogs are already adaptive. For example the property "Light power" appears when there is a light defined for an object. And a button "Modify openings" appears when there are deformations defined for the object.
Take a look at the Furniture Library Editor . This is a separate application and the most recent versions have an extended set of properties you can add to an object. You can even add your own properties so your problem may already have been solved. Although these custom added properties have no reference in the base Sweet Home 3D program they can be used by plugins that can use them because they can "know" about them. Of course this does require that furniture is added to a library before the extra properties become available, the obj/mtl model definition doesn't support these.
