Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: light fix » » » » Post: Re: light fix |
Print at Sep 9, 2026, 10:16:12 PM |
| Posted by Keet at Sep 1, 2025, 12:00:50 PM |
Re: light fix It would help if you made it clear what you want fixed. If the light is too bright/powerfull you can modify the light model. In the bottom right corner there is a setting "Light power (%)" that is default set to 50%. You can change that number to get more or less light power when rendering a photo. If it is the spread of the light then you need either a different light or add a invisible lightpanel or hemisphere. Read this very educational thread from GaudiGalopin about using invisible hemispheres to light a scene. Unfortunately all images are lost because the file host disappeared but you can still learn a lot from the text. PS Please remove your double post, the one without replies. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 9, 2026, 10:16:12 PM |
