Sweet Home 3D Forum » List all forums » » Forum: Forum in other languages » » » Thread: Help! » » » » Post: Re: Help! |
Print at Sep 9, 2026, 10:15:41 PM |
| Posted by Keet at Aug 29, 2025, 10:48:26 PM |
Re: Help! Non so nulla di Windows, ma gli elementi che ti mancano dovrebbero trovarsi in una cartella (nascosta) denominata “sweethome3d” nella tua cartella home. Nella mia installazione Linux si trova in /.eteks/sweethome3d e dovrebbe essere simile su Windows. Controlla quella cartella. Dovrebbe contenere sottocartelle per mobili, plugin ecc. (Su Windows 10 era “C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D”.) Questo è indipendente da dove si trova l'installazione effettiva di SweetHome3D. Ad esempio, la sottocartella “Mobili” dovrebbe contenere tutte le librerie di mobili (.sh3f) importate. Controlla se c'è qualcosa e facci sapere. In precedenza avevi avviato con diritti di amministratore e ora no? [English] I don't know anything about windows but the things you are missing should be in a (hidden) folder 'sweethome3d' in your home folder. On my Linux install it's in /.eteks/sweethome3d and it should be something similar on windows. Check that folder. It should have subfolders for furniture, plugins etc. (On windows 10 it was 'C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D'.) This is independent from where the actual SweetHome3D install is. For example the subfolder 'Furniture' should have all the furniture libraries (.sh3f) you imported. Check if there is anything there and let us know. Did you previously start with admin rights and now not? ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 9, 2026, 10:15:41 PM |
