Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Error -- imported new furniture, now every texture is the same! » » » » Post: Re: Error -- imported new furniture, now every texture is the same! |
Print at Sep 10, 2026, 12:49:08 AM |
| Posted by rhouck at Aug 21, 2025, 7:52:49 PM |
Re: Error -- imported new furniture, now every texture is the same! Updates: Strangely I did manage to temporarily fix it before attempting that during the process of making sure I had a backup copy of my project file per your advice. I noticed I had a previous project and, on a whim, I ended up opening it to see if the texture issue was there as well. It was not, so I then reopened the above problem project and it was fixed. But to make it stranger, when I closed and reopened, then the issue was back AND in that other project. But your (Keet's - thank you!) suggestion (swap the furniture icons viewing) did solve the issue, albeit temporarily, in both. I say temporarily because when reopening another time I actually got a different repeated texture issue. And now that seems to occur each time I freshly open it (i.e., it now picks a random texture to use for every single piece of furniture). And the toggling furniture command would no longer work. I then just went and uninstalled SH3D entirely. I then reinstalled (without adding any additional furniture libraries) and it appears to be working (fingers crossed). |
Current timezone is GMT Sep 10, 2026, 12:49:08 AM |
