Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Can't modify walls » » » » Post: Re: Can't modify walls |
Print at Sep 21, 2026, 4:33:51 AM |
| Posted by Keet at Jul 27, 2025, 10:46:29 AM |
Re: Can't modify walls You probably have accidentally locked the plan. In the top left corner of the 2D view there is a tiny lock. If it is closed you have locked the base plan which means that objects that have the "Part of base plan" property checked are locked. Some objects like walls, rooms, doors&windows have this property set by default. It means they can't be changed while the plan is locked. That is often useful when you have finished the base plan and start to fill your home with furniture. Click the lock to unlock the base plan (or Menu > Plan > Unlock base plan). ETA I missed that you have NOT locked the plan. The only other thing I can think of is that you try to edit while you have an invisible level active. Make sure that the tab of the level you are on is not grayed out, i.e. invisible. Depending on the level elevations and heights you can still see walls and windows but the active tab must be visible. That should not make a difference for walls but doors&windows can't be edited on an invisible level. As always on Windows: if nothings seems to work save your project, reboot, and try again. (I assume you can edit other furniture?) ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 21, 2026, 4:33:51 AM |
