Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Weird texture problem (bug?) » » » » Post: Weird texture problem (bug?) |
Print at Sep 9, 2026, 11:20:27 PM |
| Posted by robca at Jun 23, 2025, 2:19:52 AM |
Weird texture problem (bug?) I'm lost trying to understand what's happening with a tiled texture (I'm trying to replicate a Hardie panel siding) The texture is simply a rectangle with border I built a wall, applied that texture, then added a door. For some weird reason, the texture changes where the door ends https://www.mediafire.com/view/z20x7s4nmwaxwu...025-06-22_154702.png/file If I move the wall with the door back a bit (not the virtual camera, move the wall and door "up" in the screen), the texture renders correctly https://www.mediafire.com/view/29zfg5l984edh3...025-06-22_154825.png/file Photo rendering behaves the same Here is the file used https://www.mediafire.com/file/mvaz634fl8m4brr/texture.sh3d/file It looks as if a wall is more than 66' 11 1/4" from the origin, the problem happens. If the wall is at or below 66' 11 1/4", it doesn't happen (in metric, between 2040.2 cm and 2041.1) Which is a very big home unless, like me, you position the house in the center of a decent size lot |
Current timezone is GMT Sep 9, 2026, 11:20:27 PM |
