Print at Sep 28, 2026, 4:23:24 AM
Posted by CoffinBound at Jun 11, 2025, 3:39:12 AM
Re: 3D dimension lines plugin
@daniels118
I see that this thread is a little stale, but according to the plug-in help file, this is the correct place to post issues.
I installed this plugin with the hopes of adding dimensions to the 3D view of my house drawing. All I have been successful in doing is getting super frustrated. I watched the two videos showing how to use the tool, and yet I still struggle to get a single dimension. I watch a section of the video, pause, try to replicate, and fail every time. The very first click to start the dimension results in nothing happening or another item being selected. I tried using both videos. With the tracing paper and without it. Same result.
I have used AutoCAD in a commercial environment for over 25 years, so I was hoping this tool would be easy to use. So far, that isn't the case. I think I saw a post where you told another person that the tool hasn't been tested against the current version of SweetHome 3D. If that is true, are there plans to do this or fix any possible issues? I would be willing to supply my current drawing file for testing if that helps.
Regards,
