Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Error with picture-making » » » » Post: Re: Error with picture-making |
Print at Aug 17, 2026, 6:26:26 AM |
| Posted by db4tech at Jul 9, 2010, 5:02:34 AM |
Re: Error with picture-making Hi 32.pauls and Hans, I had the same problem couple of weeks ago, with a scene I was creating. After a process of elimination, discovered that it was caused by one of the furniture items that I had added to a scene. Hiding or deleting the problem causing furniture item instantly stopped the render problem. So as another idea it might be worth going through you used items and hiding them one at a time, then try re-rendering. If it is caused by one of your items, (after mentioning it to Emmanuel) I can tell you there is a fix and the next version of the Advanced render should not have the same problem. PS: 1024 db4tech |
Current timezone is GMT Aug 17, 2026, 6:26:26 AM |
