Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Problem: Cannot access old Furniture data files » » » » Post: Re: Problem: Cannot access old Furniture data files |
Print at Sep 24, 2026, 1:03:21 AM |
| Posted by Keet at Jun 9, 2025, 6:19:06 PM |
Re: Problem: Cannot access old Furniture data files If you have many files that you want to import in a way that they appear in the catalog you have to import them through either "Import furniture" or "Import furniturelibrary" (for .sh3f files). That can be a huge task if you have hundreds of "loose" model files. But there is trick for that: Use the Furniture Library Editor. You can select multiple obj/zip files in your filemanager and drag them in the Library Editor window: they will all be imported in the library in one drag&drop. Save the library with a fitting name and you now have a .sh3f file that only requires a single "Import furniturelibrary" in Sweet Home 3D. If you're smart you create multiple library files with a logical organization of your models. In the FLE you can select multiple models and modify them all at the same time: a good way to set the different categories for your models. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 24, 2026, 1:03:21 AM |
