Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Negative elevation of a level limitation » » » » Post: Negative elevation of a level limitation |
Print at Sep 14, 2026, 7:31:44 AM |
| Posted by Keet at May 28, 2025, 5:26:51 PM |
Negative elevation of a level limitation Today I ran into a strange limitation of level elevations: you can't create a level below -1000cm. That seems very limited to me. Creating a lake or rocket silo will easily run lower than 10 meters. I ran into the problem when I tried to add a maintenance pit for an elevator in a subway station. Simple wish: extend the negative level elevation to at least -10000cm. I can't think of any reason why this should be a problem. I temporarily(?) fixed this by editing the Home.xml file where I can easily change the level elevation to -1200 but that is not the way it should be done. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 14, 2026, 7:31:44 AM |
