Print at Oct 6, 2026, 4:34:52 AM
Posted by irlsanders at May 11, 2025, 2:39:38 AM
Re: SH3D 7.5.17 not launching on Mac OS 12.7.6
Last login: Sat May 10 16:37:41 on ttys000
/Applications/Sweet\ Home\ 3D.app/Contents/MacOS/SweetHome3D ; exit;
test@Irls-Mac-Pro-2 ~ % /Applications/Sweet\ Home\ 3D.app/Contents/MacOS/SweetHome3D ; exit;
WebOnboarding frame was null, creating new Frame
May 10, 2025 4:37:58 PM com.sun.javafx.application.PlatformImpl startup
WARNING: Unsupported JavaFX configuration: classes were loaded from 'unnamed module @396a51ab'
Loading library prism_es2 from resource failed: java.lang.UnsatisfiedLinkError: Can't load library: /Users/test/Library/Containers/com.eteks.sweethome3d.SweetHome3D/Data/.openjfx/cache/19+11/x86_64/libprism_es2.dylib
at java.base/java.lang.ClassLoader.loadLibrary(ClassLoader.java:2411)
at java.base/java.lang.Runtime.load0(Runtime.java:747)
at java.base/java.lang.System.load(System.java:1857)
at com.sun.glass.utils.NativeLibLoader.installLibraryFromResource(NativeLibLoader.java:217)
at com.sun.glass.utils.NativeLibLoader.loadLibraryFromResource(NativeLibLoader.java:197)
at com.sun.glass.utils.NativeLibLoader.loadLibraryInternal(NativeLibLoader.java:138)
at com.sun.glass.utils.NativeLibLoader.loadLibrary(NativeLibLoader.java:54)
at com.sun.prism.es2.ES2Pipeline.lambda$static$0(ES2Pipeline.java:63)
at java.base/java.security.AccessController.doPrivileged(AccessController.java:312)
at com.sun.prism.es2.ES2Pipeline.<clinit>(ES2Pipeline.java:52)
at java.base/java.lang.Class.forName0(Native Method)
at java.base/java.lang.Class.forName(Class.java:377)
at com.sun.prism.GraphicsPipeline.createPipeline(GraphicsPipeline.java:218)
at com.sun.javafx.tk.quantum.QuantumRenderer$PipelineRunnable.init(QuantumRenderer.java:92)
at com.sun.javafx.tk.quantum.QuantumRenderer$PipelineRunnable.run(QuantumRenderer.java:125)
at java.base/java.lang.Thread.run(Thread.java:832)
Loading library prism_sw from resource failed: java.lang.UnsatisfiedLinkError: Can't load library: /Users/test/Library/Containers/com.eteks.sweethome3d.SweetHome3D/Data/.openjfx/cache/19+11/x86_64/libprism_sw.dylib
at com.sun.prism.sw.SWPipeline.lambda$static$0(SWPipeline.java:43)
at com.sun.prism.sw.SWPipeline.<clinit>(SWPipeline.java:42)
Graphics Device initialization failed for : es2, sw
Error initializing QuantumRenderer: no suitable pipeline found
java.lang.RuntimeException: java.lang.RuntimeException: Error initializing QuantumRenderer: no suitable pipeline found
at com.sun.javafx.tk.quantum.QuantumRenderer.getInstance(QuantumRenderer.java:283)
at com.sun.javafx.tk.quantum.QuantumToolkit.init(QuantumToolkit.java:253)
at com.sun.javafx.tk.Toolkit.getToolkit(Toolkit.java:268)
at com.sun.javafx.application.PlatformImpl.startup(PlatformImpl.java:291)
at com.sun.javafx.application.PlatformImpl.startup(PlatformImpl.java:163)
at javafx.embed.swing.JFXPanel.initFx(JFXPanel.java:242)
at javafx.embed.swing.JFXPanel.<init>(JFXPanel.java:258)
at com.sm.sweethome3d.onboarding.web.WebOnboardingView.createView(Unknown Source)
at com.sm.sweethome3d.dialogs.DialogManager.createWebOnboarding(Unknown Source)
at com.eteks.sweethome3d.SweetHome3D.init(Unknown Source)
at com.eteks.sweethome3d.macappstore.SweetHome3DMacAppStore.init(Unknown Source)
at com.eteks.sweethome3d.macappstore.SweetHome3DMacAppStore.main(Unknown Source)
Caused by: java.lang.RuntimeException: Error initializing QuantumRenderer: no suitable pipeline found
at com.sun.javafx.tk.quantum.QuantumRenderer$PipelineRunnable.init(QuantumRenderer.java:95)
Exception in thread "main" java.lang.RuntimeException: No toolkit found
at com.sun.javafx.tk.Toolkit.getToolkit(Toolkit.java:280)
Failed to launch JVM
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
[Process completed]
