Print at Sep 10, 2026, 1:44:47 AM
Posted by igbanam at Apr 24, 2025, 4:31:37 PM
applause   Re: Dev environment setup
I managed to build the project by downloading the source code and running the build command.
1. Clone the repository
2. Inside the SweetHome3D folder, run `ant`
You must have the `ant` build tool installed. Homebrew has this.
brew install ant
You can take a look into the "build.xml" files to see how the tool is built.
There are ".project" files which instruct your IDE on how to setup the project. I develop in Vim, so my case is a bit different. But ".project" gets you enough mileage.
