Print at Sep 14, 2026, 1:31:22 AM
Posted by [email protected] at Apr 20, 2025, 4:41:29 PM
Re: Wirings plugin
Tests continued
Even changing the object (I used a 1cm high cylinder) this must always be placed 20cm above the height of the wall......
Starting from an object placed at that height and connecting it to an object placed lower, the connection occurs from the ceiling.
Lowering the first connection object retraces everything from the base and restoring the height the connection remains fixed without restoring the previous one.
The minimum height from the base plane of an object to make the direct connection to the ceiling (always 20cm above the wall) is 0.1cm.
