Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Columns, Beams, and Roofs » » » » Post: Re: Columns, Beams, and Roofs |
Print at Sep 23, 2026, 9:52:18 PM |
| Posted by Keet at Apr 17, 2025, 9:40:08 AM |
Re: Columns, Beams, and Roofs Seems like you are missing a lot of the basics. You can't use a program without knowing how it works so you will have to do a little reading. Start with the User's Guide. It's not that long and it gives you an introduction into all the basics. To get a better understanding of how levels work you can read the "Levels explained" manual on the Dodecagon site. There are several more manuals you might find interesting. You have a csv with dimensions. That should make it easy to resize boxes to create your beams and columns. Give them a wood texture. You can also import the Dimensional Lumber Library with 3D models for stick building. That library has pre-made beams you can resize. The Roof generator is grayed out because you haven't selected a Room. The generator uses a room for the base dimensions of the roof. Read the help that comes with the plugin. In your case the room you draw for the roof is a simple rectangle. In the roof generator you can make sides invisible, set an angle, etc to create a roof. Since your roof is a simple slab of metal you can also use a resized box with a metal texture. Tilt it a little to get the angle you need. By-the-way, you don't have to reboot after installing a plugin, just restart Sweet Home 3D. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 23, 2026, 9:52:18 PM |
