Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: How do you prevent one wall from bleeding into another wall » » » » Post: Re: How do you prevent one wall from bleeding into another wall |
Print at Sep 15, 2026, 6:44:54 AM |
| Posted by Keet at Apr 15, 2025, 5:13:10 PM |
Re: How do you prevent one wall from bleeding into another wall I'm not sure what you mean by "bleed into the new wall" but a wall in front of another wall should display as intended: covering the back wall. I assume you want the siding like a baseboard: only part of the wall covered. You can try three other approaches: 1 - Use sideboards for the siding (it's what they are for, best approach) 1 - Use boxes for the siding 2 - Use levels to split the walls in a lower part and upper part. Texture the lower part for the siding and the upper part as a normal wall. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 15, 2026, 6:44:54 AM |
