Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: SurroundRoom Plugin » » » » Post: SurroundRoom Plugin 1.3c |
Print at Oct 6, 2026, 5:26:01 AM |
| Posted by Xlance at Apr 15, 2025, 11:09:28 AM |
SurroundRoom Plugin 1.3c Hello Thank you for the excellent code. I took the liberty of adding a Type 7 with new functions. Object Count : The Object Count spinner lets you specify the number of objects to be placed around the room. Spacing : The Spacing spinner lets you specify the distance between edges of objects to be placed around the room. Exterior / External Offset : The spinner lets you specify the offset distance of objects from room boundary ( +values = Outwards | -values = Inwards ) Interior / Internal Offset : The spinner lets you specify the offset distance of objects from room boundary ( +values = Outwards | -values = Inwards ) Note: If you set the object count to 0, the plugin will automatically use the spacing value. Interior/Exterior Placement : You can choose whether the objects are placed inside (Interior) or outside (Exterior) the room boundaries. Spanish ApplicationPlugin_es.properties also adjusted ;-) https://www.mediafire.com/file/wpb85kb9e1n3tms/SurroundRoom-1.3c.sh3p/file Feel free to refine the code if you wish :-) ---------------------------------------- Windows 64bit | Intel i7 | SH3D 8.0 + Plugins |
Current timezone is GMT Oct 6, 2026, 5:26:01 AM |
