Print at Sep 15, 2026, 3:57:03 AM
Posted by Keet at Mar 28, 2025, 8:21:00 AM
Re: How to use 3D models with several items?
That is the one main disadvantage of the models created with AI: the result is a single object with a single texture. There is little to nothing you can do to change it. You can't add deformations to open the doors and you can't change the color/texture of individual parts.
But, the AI gives very accurate results and does it very fast!
I see two possible solutions you can try:
1. Edit out the handles from the initial picture with an image editor before running it through the AI. If the AI doesn't add handles your problem is solved. You can run a gold handle through the AI and then add the resulting object to the the generated cabinet object for each missing handle. Export them together and import again to get a single cabinet object with your gold handles.
2. Generate the cabinet picture as is and remove the handles with Blender. You only have to flatten a few faces to remove the most of the original handles. Then add the AI generated gold handles. The gold handles should display over the texture part of the original handles. You can also try this option if the AI insists on generating a cabinet with handles.
Your best hope is option 1. With option 2 there is a possibility that the cabinet texture distorts a little where you removed the original handles.
